Power Steering leaky hose/fitting
jaymdee
I've just found that I've got the same problem as in this thread :http://www.mkivsupra.net/vbb/showthread.php?190643-Power-steering-hose-part-number&highlight=power+steering+leak[ANGRY][/ANGRY]
Took some pics but it's the identical same leak from the same spot. can someone please verify this is the return side (ie not HP) and what type of hose/fitting I need to replace it with?
many thanks
Jon
cheers Daryl - couldn't believe it mate, just got car back from having a new rear wheel bearing fitted and it dumped the PS fluid !!!! Haven't driven it for 5 weeks, luckily still got MR2, lol. Just hope the pump is knackered....
Any idea how many litres I need to buy?
cheers
Good old MR2 still serving you well :)
The entire system uses about 4 litres, however at least 2 litres of that is in the rack itself which won't drain out. I think you should be able to get by on 2 litres, but best to be safe than sorry :) After disconnecting both of the rack lines on mine it didn't even use 2 litres to top it up and bleed it.
