robin Posted May 25, 2011 Share Posted May 25, 2011 I have just had the car on an alignment machine as I appear to be getting inside wear on the front tires. The rears wear evenly. Unfortunately they were unable to correct the rear toe as a couple of components are seized and need replacing. Would the current setup (attached) be likely to cause tire wear like this? Do the target settings on the machine look correct?Wheel Alignment.pdf Quote Link to comment Share on other sites More sharing options...
Nic Posted May 25, 2011 Share Posted May 25, 2011 See Service Manual for stock specifications. Quote Link to comment Share on other sites More sharing options...
