dual pillar pod
downimpact
  • 1 month later...
  • 1 month later...
A few people on here have recommended this one:
http://www.ebay.co.uk/itm/Toyota-Supra-Mk4-pillar-pod-2-Gauges-/360390331470?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53e8f00c4e
Can be 52mm or 60 mm.
Not seen it myself though.
I have one of these, quick summary;
Good points:
Is pretty well made
Fits quite well
Mine came with the holes NOT cut out - so you could cut 52 or 60mm holes. I did 60.
Bad points:
"Slightly" too short on the bit that goes over the door - and i mean slight. it does reach the rear quarter window plastic and you cant tell, but would be nice to have a little more sit inside.
No fixing brackets or anything on the inside. - Have to do this yourself, which isn't too hard, just means its not directly "plug n' play"
Will try and get a picture of mine @ lunch if it's of use to anyone.
the ebay is the one i got, went to visit the guy as he was local. Seems good enough just the righ distance, but ask him to build it up slightly and he will needs around an inch more than the mould I reckon. He will also drill them out to 60mm if you ask, I just e-mailed him rather than through ebay.
