N4FY D Posted May 23, 2011 Share Posted May 23, 2011 Ha anyone fitted a mkiii engine it their supra before and if so is it alot of work as i was just looking through ebay and you can pick up a mkiii quite cheap really Thanks Link to comment Share on other sites More sharing options...
Konrad Posted May 23, 2011 Share Posted May 23, 2011 1JZ-GTE was done few times, 7M-GTE is not worth it as those have headgasket issues. Link to comment Share on other sites More sharing options...
TRD DAN Posted May 23, 2011 Share Posted May 23, 2011 the 7m engines only had problems with torque settings once put right pretty bulletproof but the way to do it is 1jz i would say dan Link to comment Share on other sites More sharing options...
N4FY D Posted May 23, 2011 Author Share Posted May 23, 2011 Oh rite i knew the 1jz had been done i wasnt aware that the 7m-gte had problems thanks for that Link to comment Share on other sites More sharing options...
j_jza80 Posted May 23, 2011 Share Posted May 23, 2011 7M-GTE is not worth it as those have headgasket issues. the 7m can be built for big power, for less than the 2JZ. However, a 1JZ would be preferable. Link to comment Share on other sites More sharing options...
Awisto Posted May 24, 2011 Share Posted May 24, 2011 the 7m can be built for big power, for less than the 2JZ. However, a 1JZ would be preferable. I imagine the parts cost difference would be negligible and depending on power, the 7M would need strengthening long before the 2JZ Link to comment Share on other sites More sharing options...
