dani_r Posted May 23, 2011 Share Posted May 23, 2011 Can anyone recommend a good removal tool for the standard filter please? Thanks Link to comment Share on other sites More sharing options...
Tyson Posted May 23, 2011 Share Posted May 23, 2011 (edited) Have you just tried doing it by hand? Have you warmed the engine up as it will make it easier to do the oil change Edited May 23, 2011 by Tyson (see edit history) Link to comment Share on other sites More sharing options...
bodilx6 Posted May 23, 2011 Share Posted May 23, 2011 It's very hard to get a proper tool in there. Even worse if you got a sandwich plate mounted. If you can't get it out by hand (I used to remove the battery and could just reach it then with my right hand from above), I would suggest to push a screw driver through the filter and then turn it. Link to comment Share on other sites More sharing options...
Swampy442 Posted May 23, 2011 Share Posted May 23, 2011 You already have them on the end of your wrists Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 23, 2011 Share Posted May 23, 2011 Agree with the screwdriver shoved throught the side, was the only way i could get mine off without spending all day on it. Link to comment Share on other sites More sharing options...
Scott Posted May 23, 2011 Share Posted May 23, 2011 Used to tighten and to loosen oil filters along with all manor of other things Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 23, 2011 Share Posted May 23, 2011 http://www.autoexpress.co.uk/products/products/53439/clarke_oil_filter_claw_wrench_cht424.html I use something very similar, lots of different people sell this style removal tool, but I access it from underneath on a ramp. Link to comment Share on other sites More sharing options...
bodilx6 Posted May 23, 2011 Share Posted May 23, 2011 Chris Wilson said: http://www.autoexpress.co.uk/products/products/53439/clarke_oil_filter_claw_wrench_cht424.html I use something very similar, lots of different people sell this style removal tool, but I access it from underneath on a ramp. Got one of those. Only ever managed to fit it on my peogout 206 as there is plenty of room . Really good tool though, if it can get in there. As Chris describes, it can be done from below where there is a small "access plate" you can remove that makes it a tiny bit easier to get to. I've just relocated it when I installed an oil cooler. That helped. Somewhat ;-) Link to comment Share on other sites More sharing options...
Scooter Posted May 23, 2011 Share Posted May 23, 2011 I use the metal belted type, the type in chris's link on the right for £5.95. They get a good grip on the filter and are long enough to give you enough leverage to get it the quarter or so of a turn (2-3 loosen and tighten cycles as you can usually only turn it 10-20 degrees or so with the limited access) you need to loosen a stiff one before it becomes doable by hand. Link to comment Share on other sites More sharing options...
stevie_b Posted May 23, 2011 Share Posted May 23, 2011 Any strap wrench. Don't use a chain-based one: they're liable to perforate the oil fitler and make a bit of a mess. Link to comment Share on other sites More sharing options...
garethr Posted May 23, 2011 Share Posted May 23, 2011 Buy one of these (I believe 74mm x 14 flutes is correct for the standard Toyota filter, but check whatever filters you use). It makes changing the filter a piece of the proverbial (at least it does on the Soarer and Aristo). http://www.lasertools.co.uk/item.aspx?cat=375&item=1090 Link to comment Share on other sites More sharing options...
Iky Posted May 23, 2011 Share Posted May 23, 2011 Ive used one of these on the Supra. http://photos.autoexpress.co.uk/images/front_picture_library_UK/dir_36/car_photo_18182_7.jpg Link to comment Share on other sites More sharing options...
dani_r Posted May 24, 2011 Author Share Posted May 24, 2011 garethr said: Buy one of these (I believe 74mm x 14 flutes is correct for the standard Toyota filter, but check whatever filters you use). It makes changing the filter a piece of the proverbial (at least it does on the Soarer and Aristo). http://www.lasertools.co.uk/items/medium/3801.jpg http://www.lasertools.co.uk/item.aspx?cat=375&item=1090 Cheers for your replies chaps! I've actually bought this tool, i'm just hoping there's room in there for me to get at the filter and actually use the tool! I will let you know how I get on. BTW - 74mm and 14 flats is right Link to comment Share on other sites More sharing options...
Scott Posted May 24, 2011 Share Posted May 24, 2011 Have you tried your hands? Get both of them in there with a wet rag and give it a twist. I've not had one that I can't get off with my mits yet. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2011 Share Posted May 24, 2011 It's all right for you Jocks, all that tossing you do makes your hands and arms exceptionally well developed. Those cabers sure look heavy Link to comment Share on other sites More sharing options...
Scott Posted May 24, 2011 Share Posted May 24, 2011 I'll be honest, I've never tossed a caber. I've always fancied giving it a go though Link to comment Share on other sites More sharing options...
bignum Posted May 24, 2011 Share Posted May 24, 2011 This is the tool ive just ordered, you can use it for other jobs also:eyebrows: http://rover.ebay.com/rover/0/e11400.m516.l1123/7?euid=522900df777842ee89bc4fa4d3a05a15&loc=http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item%3D310307746843%26ssPageName%3DADME:L:OC:GB:1123 Link to comment Share on other sites More sharing options...
monsween Posted May 24, 2011 Share Posted May 24, 2011 Scott M said: I'll be honest, I've never tossed a caber. I've always fancied giving it a go though You've tossed something else tho...... The proper tool for the job below Link to comment Share on other sites More sharing options...
Scott Posted May 24, 2011 Share Posted May 24, 2011 bignum said: This is the tool ive just ordered, you can use it for other jobs also:eyebrows: http://rover.ebay.com/rover/0/e11400.m516.l1123/7?euid=522900df777842ee89bc4fa4d3a05a15&loc=http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item%3D310307746843%26ssPageName%3DADME:L:OC:GB:1123 James Bond movies? Link to comment Share on other sites More sharing options...
