nigelboyne Posted May 22, 2011 Share Posted May 22, 2011 anyone help how to turn service light indicator of on 2010 audi a4 1.8tfsi thanks Quote Link to comment Share on other sites More sharing options...
L18msy Posted May 22, 2011 Share Posted May 22, 2011 The wife has a 2007 A4 tdi and i switched hers off with an Ethos diagnostic machine, there is also a sequence you can do using brake pedal, ignition and a button but can't remember exactly. I will try and find out for you. Quote Link to comment Share on other sites More sharing options...
JakeG Posted May 22, 2011 Share Posted May 22, 2011 Hold 0.0 button switch ignition on, release 0.0 button then press the min button, that's how to reset VW Jetta, not sure if a4 is the same Quote Link to comment Share on other sites More sharing options...
L18msy Posted May 22, 2011 Share Posted May 22, 2011 Checked the audi handbook there, here goes. Switch off ignition Press and hold spanner button on the instrument cluster while switching on ignition The display will show either: service in ....km or service! Press 0.0 button until service in 2000km or...days or service! is in display And got to be done within 5 secs. Hope that helps Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 23, 2011 Author Share Posted May 23, 2011 thanks guys will try the above Quote Link to comment Share on other sites More sharing options...
