Track day brake issue or not?
downimpact
This has been going on for some time and was hoping for an answer. On any track day after a session, once the car has cooled ready to go out again, the first time I go to use the brakes the pedal travels excessively without significant stopping power. If I pump the brakes they then go hard again and back to normal. This happens after every session on track.
I've recently changed from jap spec to UK brakes and both do the same thing, is this normal and what's causing it?
Fluid was changed within the last month.
id go with air in the lines 100%,im running a standard brake set up and no matter how hard i drive on the track the brakes have never faded or done anything like this,the tyres go off before anything.boiling the power steering fluid yes but brakes no.defo bleed em up and if your not already run dot 5 fluid
yeah have braided lines and highest temp racing fluid I could find (better than Motul's 5.1). I wondered about boiling it though don't have any issue while on track with fade. This has happened for a number of years after a number of brake fluid changes, which I suspect mean it's something else?
Dirty fluid in the MC may have blocked the fluid return bleed hole. A new MC would be nice, a full strip and clean, with a new OEM seal kit, next best.
Do you probably have a Part Number for the Seal kit? Mine does the same to a certain point after this weekend at the Nüburgring.
