Fuel cut and emanage
Vaughany
Hi everyone, I have a PHR stage 1 single turbo that is set up on the emanage. I am currently running 1.4 bar but i have noticed that the fuel cut parameter has not been set up.
Would I be right in saying that running a single with bigger injectors (PE 650cc) I do not need to set a fuel cut. I have obviously not hit the fuel cut but I was wandering why I dont need to set this. I had the emanage on when I was running stock twins and 440's and the fuel cut was set.
Why is it different on the new setup?
With bigger injectors you will be scaling the airflow signal down so the ECU scales the amount of fuel down. That means that at full 1.4 BAR the ECU will be seeing less than 1 BAR, so will never invoke fuel cut.
Yay :thumbs:
As an extra freebie bit of info, when the stock ECU sees 1bar of boost it runs 100% duty. As you have man enough injectors for the job, you will never need 100% duty, therefore you will never send the ECU an airflow signal indicating 1bar of boost, therefore you'll never instigate fuel cut :)
-Ian
I think you'd have to max out your injectors. Cause then you're fuel map would have lots of 0's and no fuel pulled out of the map. Therefore the ECU would see "stock" voltages and you'd hit the FC.
It depends on injector size, rail pressure and turbo size for starters...it's should be a lot of boost!
