Best way to get oil off a brick drive way
bradleyh_15
It looks a mess for a bit. But i have used Flower (the stuff you use for cooking) To clear it up.
I can't remember how long it takes but it worked really well.
You cook with flowers?? Or do you mean flour ;) Absorbant granuals might help, and next time get some drip trays lol
Brick acid is good, also washing up liquid with a small amount of water allowed to soak in, keep applying over days (just pour on). The idea is to let it penetrate as far as the oil, people make the mistake of putting something on and washing it off straight away and this only takes away the surface oil.
sounds like something I can do now I'll give it a go and ill go get brick acid tomorrow and if it does not work I'll use the acid! ;)
Thanks guys such a wealth of knowledge on hear :)
