davep Posted May 20, 2011 Share Posted May 20, 2011 the expantion tank has filled up extreamly quick and the engine gets warm quick just wondering if this is right as it never used to Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 20, 2011 Share Posted May 20, 2011 Radiator cap gone bad? Is it overheating when driving or does it run at normal temps? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2011 Share Posted May 21, 2011 Yes, try a new radiator cap. Clean the mating surfaces. Quote Link to comment Share on other sites More sharing options...
davep Posted May 21, 2011 Author Share Posted May 21, 2011 it does not seem to over heat but when i take the rad cap off the water does overflow out the rad a bit Quote Link to comment Share on other sites More sharing options...
TT Paul Posted May 21, 2011 Share Posted May 21, 2011 it does not seem to over heat but when i take the rad cap off the water does overflow out the rad a bit is that when its warm if so it will due to pressure escaping. check the cap as they said next step flush system through maybe Quote Link to comment Share on other sites More sharing options...
