Speedhut supra oil pressure gauge
Robzki
Speedhut white face 52mm oil pressure gauge in psi with loom sender etc etc. never fitted I'm fairly sure the instructions are around here too. This has the supra logo on the gauge
£35 delivered. Paypal fine but you pay the fee
Rob
how easy is it to fit?
I've just fitted one, You will need a sandwich plate or a tapped sump plug. I went for a sandwich plate when I put mine in. £25 ish from ebay then just a cable from the sender to behind the dash, then join up the power cable inside to a suitable power source for the lighting. the 52mm gauge fits nicely in the clock hole :)
