Scutch0 Posted May 20, 2011 Share Posted May 20, 2011 Just had a warning light come up on panel just below the adometer showing a car simbol with lines coming out the back of it? Any ideas? Turned the ignition off and on and it hasn't re appeared? I've just had the back bumper resprayed so I'm assuming it had something to do with that? Link to comment Share on other sites More sharing options...
Robzki Posted May 20, 2011 Share Posted May 20, 2011 Rear light bulb blown or disconnected? Your description sounds like that warning light, but not sure where it is in the supra. try all lights and see if it reappears. Its poss not on now as you haven't used that circuit, brakes, indicator, reverse etc Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 20, 2011 Share Posted May 20, 2011 A car with 2 'wiggly' lines coming out the back of it?? Sounds like a traction control kind of light to me. Link to comment Share on other sites More sharing options...
Scutch0 Posted May 20, 2011 Author Share Posted May 20, 2011 Well mine is a n/a without t/c. I'll take a pic of it when I can! Link to comment Share on other sites More sharing options...
David P Posted May 20, 2011 Share Posted May 20, 2011 (edited) Just had a warning light come up on panel just below the adometer showing a car simbol with lines coming out the back of it? Any ideas? Turned the ignition off and on and it hasn't re appeared? I've just had the back bumper resprayed so I'm assuming it had something to do with that? Maybe it's a 'Paint still drying on the bumper' warning light. Edited May 20, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
Tyson Posted May 20, 2011 Share Posted May 20, 2011 http://www.mkivsupra.net/vbb/showthread.php?155810-Dash-Lights...-What-do-they-all-mean blown bulb warning, loose cable to one of the bulbs probably if its gone back off. Link to comment Share on other sites More sharing options...
Suprab1 Posted May 20, 2011 Share Posted May 20, 2011 Check your number plate bulbs if the bumper was off for spraying. Link to comment Share on other sites More sharing options...
Scutch0 Posted May 21, 2011 Author Share Posted May 21, 2011 Super. That makes sense, I had a quick look an one of the bulbs was loose! I'm actually amazed at how advanced the supra was for its age, a car that was released about 18 years ago and it has bulb failure warning lights? Not even all new cars have that yet! Just goes to show it was advanced for its time! Link to comment Share on other sites More sharing options...
