adi2009 Posted July 5, 2005 Share Posted July 5, 2005 Just to clarify, can you pull the wire from the sub-throttle in a J-spec car to disable the traction control system or does this only apply for UK/US spec cars. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 5, 2005 Share Posted July 5, 2005 Nope, not in J-spec Supras Quote Link to comment Share on other sites More sharing options...
adi2009 Posted July 5, 2005 Author Share Posted July 5, 2005 Thanks for that Jake!!! Is there any problem with removing it though??? I am asking this because in my NA-TT swap, the wiring loom only has 4 wires that connect to the connector but the sub-throttle has 6 wires. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 5, 2005 Share Posted July 5, 2005 Sorry mate, I've no idea Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 5, 2005 Share Posted July 5, 2005 You can pull the traction control ECU to disable the traction control -Ian Quote Link to comment Share on other sites More sharing options...
adi2009 Posted July 5, 2005 Author Share Posted July 5, 2005 in my NA-TT swap, the wiring loom only has 4 wires that connect to the connector but the sub-throttle has 6 wires. I havent connected the sub-throttle to the wiring loom due to the above reason and my car does not idle properly. It keeps fluctuating about 300rpm up and down and each cycle takes approx 1 second, so its kinda worrying me. I m not sure whether this is happening because the sub-throttle isnt connected Quote Link to comment Share on other sites More sharing options...
Markie Posted July 6, 2005 Share Posted July 6, 2005 Can you connect it and see if it changes? Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 6, 2005 Share Posted July 6, 2005 I havent connected the sub-throttle to the wiring loom due to the above reason and my car does not idle properly. It keeps fluctuating about 300rpm up and down and each cycle takes approx 1 second, so its kinda worrying me. I m not sure whether this is happening because the sub-throttle isnt connected I very much doubt this is to do with your traction control, it has nothing to do with idle. Got any error codes? What's your O2 readings? -Ian Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 6, 2005 Share Posted July 6, 2005 Sub throttle is totally removed from my car, and it hasn't caused any adverse effects. Quote Link to comment Share on other sites More sharing options...
adi2009 Posted July 7, 2005 Author Share Posted July 7, 2005 Thanks for all your responses I just got around to checking the error codes and i got code # 21, I think this is supposed to indicated some problem with the Main Oxygen sensor signal. So what should i do now??? Error code details (second pic from the left) http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=error+codes Quote Link to comment Share on other sites More sharing options...
