Putting the feelers out (Broken w58)
Kirk
Ideally an entire box to strip and rebuild as im bored at the minute :D
My 1st and 2nd gears are a little tough to engage at times, thinking its probably the syncro's so be nice to have spares around or a fully rebuilt box should the worst happen.
You might as well pick up a gearbox that is supposed to be in good working order.
The trouble with picking up a gearbox that definitely needs work is that theres a chance you could get a box like mine, with the output shaft buggered and you wouldn't have a clue until you split it.
You could find yourself with a lot of completely knackered W58s very quickly!
