Mark's NA Supra at Invisible Touch
Stonkin
Hi,
Here we have Mark's NA Supra from the forum booked in for a stage 1 paint enhancement. These are the pictures over the course of its transformation.
After Mark's long journey
First off the wheels were cleaned with Bilberry and tyres with APC
It was then jet washed and snow foamed
After being washed via 2 bucket method with Shampoo Plus, these were some defects caught in the sunlight. The fairly new Seibon bonnet suffering from buffer trails after production
The Supra was then clayed inside and washed again. The levels of contamination robbing the paint of its metallic finish
Paint thickness readings were then taken. The car had recieved various paint over the years. Some areas were better than others
Inspecting the finish with LED and halogen lighting
One final pic before starting
Polish to be used was Menzerna 106fa. Not all defects would be removed with a stage 1 but this would give us enough level of cut whilst also refining to a good finish
Using the Makita rotary, 3M backing plate for control and 3M polishing pad
Preparing the rear wing
50/50's
Moving onto the passenger door
Round to the front wing
Taped up
Showing the level of clearcoat removal from polished to unpolished
Starting to look better
Drivers wing
Passenger wing
Onto the carbon bonnet which Mark thought would not need much attention :) Carbon can quickly oxidise over time if unprotected
Completed
Drivers side
Rear wing looking a bit sorry for itself
All other areas were then completed. The wheels were treated with Sealant, tyres dressed with Endurance Gel, exhaust polished with NXT, headlights machined, Glass polished, interior was hoovered and dusted down. After this the paint was wiped down with an IPA solution to remove polishing oils. I then applied Dodo Juice Lime Prime Lite as a glaze and pre-wax cleanser and finally it was protected with 1 application of Victoria Concourse wax.
These were the final pics
  Quote
b;3118378']http://i27.photobucket.com/albums/c194/Stonkin/NA%20Supra/DSC02985.jpg
Wow! Talk about before & after :)
Fair play you do some brilliant work. Certainly giving vehicles paintwork a new lease of life. Very nice work. :thumbs
That was the pic that did it for me too. I didn't think it looked that bad before, but it's like comparing an old banger to a brand new car in that pic. Stonking! :)
Seen this car at the weekend and the finish was nothing but spectacular. Got some nice video clips of it on the motorway as well:)
Well done christian and congrats Mark, the next little upgrade will make the interior as nice as well;):D
