Round metal things on the bottom of the side windows.
little num
Ok im fitting some plastic windows (drivers - passenger doors) but need to drill the fixing holes in the new plastic windows, this isnt a problem but what is, is taking the round fixing washers off the glass windows.
Ive tried forcing them off with a screw driver but no such luck.
Does any1 here know how to remove these without breaking the glass.
Sorted now, for anybody interested they screw apart using the 4 little cut outs, but be aware they are very very tight and you will need to make a tool to fit both sides as when turning 1 the other turns with it.
I cut sections out of a socked to leave 4 pins sticking out and then cut them to size X 2 then undid the quite easy.
