Oil filter sandwich plate..
d-_-b
Hey guys,
I need an oil filter sandwich plate to fit 2 sensors: 1 x temp, 1 x pressure
Anyone have any recommendations for plates (/brands) they have used in the past / where to get one from or is it more a case most will do the job & so eBay.
Thanks in advance for any help :)
Edited by d-_-b (see edit history)
  • 1 month later...
3/4 UNF IIRC.
Any old plate should do the trick to be honest. The seals allow the tolerancing to be pretty loose. Don't go for any old junk if you're looking for an oil cooler plate though.
Cheers Scott - Your a star! :hi: :thumbs:
  • 1 year later...
b;3117871']Hey guys,
Did you have any clearance issue when fitting this plate to your TT? Are you using the bigger Lexus oil filter?
Wow an old thread of mine from the past!
Mine isn't a TT, but think same applies for N/A & TT
I didnt have any clearance issues, and im using a stock, what I would term a 'standard height' oil filter if that helps dude..
