d-_-b Posted May 18, 2011 Share Posted May 18, 2011 (edited) Hey guys, I need an oil filter sandwich plate to fit 2 sensors: 1 x temp, 1 x pressure Anyone have any recommendations for plates (/brands) they have used in the past / where to get one from or is it more a case most will do the job & so eBay. Thanks in advance for any help Edited June 21, 2011 by d-_-b (see edit history) Quote Link to comment Share on other sites More sharing options...
aman00123 Posted May 18, 2011 Share Posted May 18, 2011 I think most will do the job really, but I got mine from a company called Rspec - http://www.rspec.co.uk/ Quote Link to comment Share on other sites More sharing options...
d-_-b Posted May 19, 2011 Author Share Posted May 19, 2011 Cool, thanks aman, will check out the link Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 21, 2011 Author Share Posted June 21, 2011 What version would I need - 3/4UNF-16? Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 22, 2011 Author Share Posted June 22, 2011 Anyone with a quick reply to the above? Quote Link to comment Share on other sites More sharing options...
aman00123 Posted June 22, 2011 Share Posted June 22, 2011 If you give a supplier a ring they'll know bud Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 22, 2011 Author Share Posted June 22, 2011 If you give a supplier a ring they'll know bud Yh sure they would, just thought with however many hundreds of members on here someone would of known that was all.. Quote Link to comment Share on other sites More sharing options...
Scott Posted June 22, 2011 Share Posted June 22, 2011 3/4 UNF IIRC. Any old plate should do the trick to be honest. The seals allow the tolerancing to be pretty loose. Don't go for any old junk if you're looking for an oil cooler plate though. Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 22, 2011 Author Share Posted June 22, 2011 3/4 UNF IIRC. Any old plate should do the trick to be honest. The seals allow the tolerancing to be pretty loose. Don't go for any old junk if you're looking for an oil cooler plate though. Cheers Scott - Your a star! Quote Link to comment Share on other sites More sharing options...
monsween Posted June 22, 2011 Share Posted June 22, 2011 Just had a look at the one i have here and Scott looks to be correct Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 22, 2011 Author Share Posted June 22, 2011 Just had a look at the one i have here and Scott looks to be correct Brilliant thankyou for the extra confirmation dude, is muchly appreciated! Quote Link to comment Share on other sites More sharing options...
monsween Posted June 22, 2011 Share Posted June 22, 2011 I also have a spare one i think Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted February 26, 2013 Share Posted February 26, 2013 b;3117871']Hey guys, I need an oil filter sandwich plate to fit 2 sensors: 1 x temp, 1 x pressure Anyone have any recommendations for plates (/brands) they have used in the past / where to get one from or is it more a case most will do the job & so eBay. Thanks in advance for any help Did you have any clearance issue when fitting this plate to your TT? Are you using the bigger Lexus oil filter? Quote Link to comment Share on other sites More sharing options...
d-_-b Posted February 26, 2013 Author Share Posted February 26, 2013 Did you have any clearance issue when fitting this plate to your TT? Are you using the bigger Lexus oil filter? Wow an old thread of mine from the past! Mine isn't a TT, but think same applies for N/A & TT I didnt have any clearance issues, and im using a stock, what I would term a 'standard height' oil filter if that helps dude.. Quote Link to comment Share on other sites More sharing options...
Fly Posted February 26, 2013 Share Posted February 26, 2013 i found the ford oil filter is slightly smaller and the same fitment if you do have any issues with space Quote Link to comment Share on other sites More sharing options...
