Toyota Supra UK Black Manual T67 500bhp
weskereric
Time has come to sell as I need cash for other cars.
I would like offers in the region of £17000 (depending on current £/€ rate)
It's a 1993 Black UK Spec Manual Supra with 500bhp. Engine has just 2000 miles and chassis is about 130k miles.
Car is located in South of France but could be collected in Paris or I could deliver it :)
This is the spec :
Engine :
Rebuilt engine with stock headgasker and cecured, ARP Racing head studs and fasteners and jspec cams
K&N air filter
4" polished intake pipe
HKS Intercooler, HKS hard piping and hosing
HKS Type S FMIC
Smoothed stock inlet manifold
Koyo radiator
Precision T67 Turbo with BL braided oil lines
HKS replica tubular manifold
Tial 44mm External wastegate with 2inch Screamer pipe
AEM Boost control solenoid
Boost Logic downpipe and mid pipe with AEM wideband Air/Fuel Ratio Sensor
HKS SuperDragger Intermiediate and rear exhaust 5inch slash cut
NGK grade 8 plugs
HKS DLI Ignition
Fuel system :
880cc Precision Fuel Injectors
HKS Fuel rail anodised blue
16mm Fuel feed line, twin 16mm feed to fuel rail
10mm Fuel return line
Aeromotive Fuel pressure regulator
Walboro 255 Fuel pump
Transmission :
6 Speed Getrag
Stock flywheel
RPS 6 Paddle Max Sport Clutch
UK Diff and Diff radiator
Chassis :
Titan Anti Roll bars (~4000miles)
Tein flex coilovers (~4000miles)
Performance Friction Race pads (~4000miles)
OEM Discs (~4000miles)
Braided Brake lines
18" Rota GTR wheels
Toyo R888 245 front/285 rear (~4000miles)
DOT 5.1 Brake liquid
Electronics :
AEM EMS full standalone ecu
Switchable boost maps 1.1bar and 1.4bar
Launch control with anti lag
AEM Wideband Air/Fuel Ratio gauge
Interior :
OMP Racing 4point Harness's
Front and rear Black leather seats
I take it though that it would be classified as an import if it came back to the UK?
It shouldn't do. I believe it's only an import if it was originally built in another country. You will still call up insurers and say, "I bought a UK spec... insure me."
New pictures (not very clean :D) :
https://lh6.googleusercontent.com/_ao5cKlSAKw4/TdVqaYwPKvI/AAAAAAAACKk/tw2GzCB_bus/225224_1721195509799_1235652980_31518975_5184547_n.jpg
https://lh3.googleusercontent.com/_ao5cKlSAKw4/TdVqbJEdVUI/AAAAAAAACKo/PymPF52qjz8/226237_1721196989836_1235652980_31518981_3140141_n.jpg
https://lh4.googleusercontent.com/_ao5cKlSAKw4/TdVqblvwLGI/AAAAAAAACKs/BRcbfOpAQLU/225255_1721196629827_1235652980_31518980_7831532_n.jpg
https://lh5.googleusercontent.com/_ao5cKlSAKw4/TdVqckypDTI/AAAAAAAACKw/COSgi4L7fUA/227576_1721197149840_1235652980_31518982_7760510_n.jpg
https://lh5.googleusercontent.com/_ao5cKlSAKw4/TdVqdA7_1LI/AAAAAAAACK4/eQ-C7iLvWyw/230678_1721197869858_1235652980_31518984_6220359_n.jpg
