Greddy Plenum Fitting
add heywood
I remember seeing somewhere the Greddy manual for fitting the intake to the 2JZ GTE.... but cant seem to find it anywhere :search: It had a list of parts that you needed with it to install.
Ive found you need a longer throttle cable (Celica GT4 I have been told) to fit to a Q45.
Would some of these 80mm ebay throttle bodies work instead of a Q45, although I dont really want to weld a flange to the end of the intake to take a different TB if I can help it.
Also is there an adapter for the throttle position sensor you can get so it clips in, or is it easier to hardwire on to the original nissan one.
