Cambelt change cars not starting now..
Guest anesn
Guest anesn
Hey guys, yesterday i changed cambelt , tensioners and crankshaft front seal. When i put everything back the car doesn't want to start. The timing marks are 100% correct When i took away the crank timing pulley i bended the timing rotor/Trigger wheel i bended it back as good as i could. When im using diagnostic on it im getting code #12
http://mkiv.supras.org.nz/articles/engine_2_12.htm
When i take out the contact from crank position sensor the car will just go on the starting motor and nothing more. If i put it in its trying to start but missfiring sometimes and shit. Could a bent Trigger wheel couse this error code and this behaviour? if it can where can i buy this trigger wheel or Crank timing pulley
Thank you.
  • 1 month later...
