sdistc Posted June 16, 2011 Share Posted June 16, 2011 Nice work Am thinking of giving this a go myself, but not sure I have the minerals yet Link to comment Share on other sites More sharing options...
leelbuk Posted June 16, 2011 Share Posted June 16, 2011 Are you going to check the valve lash whilst in there? To all those here with doubts about doing this DIY I can understand where you are coming from - there is quite a mental barrier in the way of doing some open heart surgery on the engine. Before doing mine the most mechanical experience I had was changing discs and pads, oil etc. but I pride myself in having a decent amount of common sense. I managed to get though it ok so I imagine that many others, more mechanically adept with some common sense of their own can do the same. Just be clean and careful not to ding anything. It does take some stomach though so fair play for taking the plunge! Will all be worth it when it fires up after doing the work yourself - smoke free and all! Link to comment Share on other sites More sharing options...
dude Posted June 17, 2011 Share Posted June 17, 2011 Lay a rag in the valley just incase something trys to fall down a plug hole;) TBH I will not change stem seals this way anymore as I have not seen a car with stem seals gone that did not need some or all valves re lapping, the time difference in removing the head and doing it this way is not so great. Make sure you have a small torque wrench that goes down to 14ft lbs for the cams. There is no reason for any job to be out of reach to a reasonably mechanically minded person but some people have no idea they try and map cars themselves with no idea or diagnostic equipment, I have seen some horrendously repaired accident damaged supras that the customer actually believe are safe when in reality they are as bent as a banana, ive even seen some people claim to have fitted new oil pumps when the 1) the pump clearly has not been off and 2) then told 'oh we fitted a secondhand pump !!!!. If you are in ANY doubt if something feels or has gone back right then just try and get someone to have a listen, don't chance it. But if you lose a collet you need to make sure it is not down a plug hole or under a spring etc, if it is in the head somewhere it will eventually cause a lot of damage. If you struggle I have a very easy to use tool for compressing the valves to get the collets back in as I just cannot get on with the snap on hit it with a hammer one. My tool works like a normal valve spring compressor but instead of holding the valve it uses leverage from a rod mounted on the head and an angled crank with valve compressor, a courier would be cheap if you need to borrow it. Link to comment Share on other sites More sharing options...
mellonman Posted June 17, 2011 Share Posted June 17, 2011 (edited) There is no reason for any job to be out of reach to a reasonably mechanically minded person but some people have no idea they try and map cars themselves with no idea or diagnostic equipment, I have seen some horrendously repaired accident damaged supras that the customer actually believe are safe when in reality they are as bent as a banana, ive even seen some people claim to have fitted new oil pumps when the 1) the pump clearly has not been off and 2) then told 'oh we fitted a secondhand pump !!!!.. i see you talking about me lol Yes it is amazing what some places think they can get away with, thats why i went to better garage but had similar problems and was told lies ! mapping with no diagnostic equipment thats true but only on the off throttle problem in closed loop that the garrage could not fix,so matters into own hands and what do you know i have done it with no diagnostic tools just abit of research and tweaking with the fuel trim so that the 2 ecus was not fighting each other in closed loop. Just so everone knows the fic can be used as a fcd and if left in the fcd conflicts with the fic this maybe down to 3 units trying to minipulate 1 singal that can cause det as the stock ecu with think there is alot less boost then there is So Sorry for that Edited June 17, 2011 by mellonman (see edit history) Link to comment Share on other sites More sharing options...
marc_p Posted June 17, 2011 Author Share Posted June 17, 2011 Lay a rag in the valley just incase something trys to fall down a plug hole;) TBH I will not change stem seals this way anymore as I have not seen a car with stem seals gone that did not need some or all valves re lapping, the time difference in removing the head and doing it this way is not so great. Make sure you have a small torque wrench that goes down to 14ft lbs for the cams. There is no reason for any job to be out of reach to a reasonably mechanically minded person but some people have no idea they try and map cars themselves with no idea or diagnostic equipment, I have seen some horrendously repaired accident damaged supras that the customer actually believe are safe when in reality they are as bent as a banana, ive even seen some people claim to have fitted new oil pumps when the 1) the pump clearly has not been off and 2) then told 'oh we fitted a secondhand pump !!!!. If you are in ANY doubt if something feels or has gone back right then just try and get someone to have a listen, don't chance it. But if you lose a collet you need to make sure it is not down a plug hole or under a spring etc, if it is in the head somewhere it will eventually cause a lot of damage. If you struggle I have a very easy to use tool for compressing the valves to get the collets back in as I just cannot get on with the snap on hit it with a hammer one. My tool works like a normal valve spring compressor but instead of holding the valve it uses leverage from a rod mounted on the head and an angled crank with valve compressor, a courier would be cheap if you need to borrow it. Cheers dude:thumbs: Last night I tried to use the tool I have for removing collets, but for want of a better word, it was a piece of poop so I ordered the Snap-On one last night and I'll see how I get on with that, thanks for the offer though Dude, I'll see if I can get the Snap on one to work first and let you know Link to comment Share on other sites More sharing options...
leelbuk Posted June 17, 2011 Share Posted June 17, 2011 I managed to do this with the snap-on tool but if doing it again I'd definitely take up John's offer and use that tool as the risk of damaging the head is too high with the snap-on tool. I was paranoid throughout the entire job and covered nearly every inch of the tool with insulating tape to lower the risk, but only a little. Block every orifice in the head to stop bits falling in anywhere, keep a magnetic tool handy and make sure you have a lot of patience and rush nothing! Link to comment Share on other sites More sharing options...
mellonman Posted June 27, 2011 Share Posted June 27, 2011 Any joy Link to comment Share on other sites More sharing options...
marc_p Posted June 27, 2011 Author Share Posted June 27, 2011 Any joy Got my tool on friday so got about 5 out of 24 done, getting then out is easy, it's getting the valve retainers back in that's a pain in the arse. You don't need to hit the tool with a hammer to get them out though, I was nervous about doing that in case I slipped, so I decide just to try and do it by just pushing it and they came out fairly easy(about 3 or 4 pumps). Link to comment Share on other sites More sharing options...
mellonman Posted June 27, 2011 Share Posted June 27, 2011 so how hard of a job is it would you say? Link to comment Share on other sites More sharing options...
marc_p Posted June 27, 2011 Author Share Posted June 27, 2011 so how hard of a job is it would you say? As long as you take your time it's fine, I'm not rushing it and just following the guide, trust me when I say, if I can do it, anyone can. Valve retainers are getting easier now, managed to do 5 valves in an hour tonight, so will stick to 5 a night then I can reassemble the car over the weekend. I really would recommend removing the rad though, it's an easy job and makes it a lot easier when removing the parts. Link to comment Share on other sites More sharing options...
dude Posted June 28, 2011 Share Posted June 28, 2011 As long as you take your time it's fine, I'm not rushing it and just following the guide, trust me when I say, if I can do it, anyone can. Valve retainers are getting easier now, managed to do 5 valves in an hour tonight, so will stick to 5 a night then I can reassemble the car over the weekend. I really would recommend removing the rad though, it's an easy job and makes it a lot easier when removing the parts. If you had used my tool it takes about 1 min to get each set of collets back in and about 10 secs to get em out with no risk to the head, thats after you have it bolted down etc. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 28, 2011 Share Posted June 28, 2011 If you had used my tool it takes about 1 min to get each set of collets back in and about 10 secs to get em out with no risk to the head, thats after you have it bolted down etc. My tool is special too, fine screwdriver with a dab of grease on the end to hold the collet. Link to comment Share on other sites More sharing options...
mellonman Posted June 28, 2011 Share Posted June 28, 2011 My tool is special too, fine screwdriver with a dab of grease on the end to hold the collet. wow the advances in techology are amazing these days lol if it does the job it does the job cant knock it in anyway Link to comment Share on other sites More sharing options...
dude Posted June 28, 2011 Share Posted June 28, 2011 My tool is special too, fine screwdriver with a dab of grease on the end to hold the collet. You ALWAYS need the fine screwdriver with grease, I know of no other way to get the collets back in the groove on the valve. Link to comment Share on other sites More sharing options...
marc_p Posted July 13, 2011 Author Share Posted July 13, 2011 It's alive!!!!! Just finished it and ran it for a couple of mins, purred like a cat:) Now I just have to set up the boost controller. Link to comment Share on other sites More sharing options...
Homer Posted July 13, 2011 Share Posted July 13, 2011 Well done Marc Link to comment Share on other sites More sharing options...
mellonman Posted July 14, 2011 Share Posted July 14, 2011 good one marc so how many beers did you have while doing it lol. i think i need mine doing very soon as i have masses of black smoke on first start up and first drive off of the day Link to comment Share on other sites More sharing options...
marc_p Posted July 14, 2011 Author Share Posted July 14, 2011 good one marc so how many beers did you have while doing it lol. i think i need mine doing very soon as i have masses of black smoke on first start up and first drive off of the day Not many suprisingly:d, it's all about just taking your time and being methodical, I do recommend removing the radiator though, makes the job 10x easier for removing items like the cambelt tensioner, also I wouldn't hit the collet remover with the hammer, there is too much risk of hitting the head in my opinion, just give it some nice firm pumping action by hand (2-3 pumps and they come out), other than that, I followed T-Licences guide word for word and found it perfect, everything is covered. Link to comment Share on other sites More sharing options...
Josh Posted July 14, 2011 Share Posted July 14, 2011 Nice one, Marc! Think I might have to give mine a go at some point. Link to comment Share on other sites More sharing options...
