marc_p Posted May 17, 2011 Share Posted May 17, 2011 As above, I have been a complete tool and as I was replacing some vac pipes, I managed to snap off the plastic tube part of the VSV (pn:90910-12126-B), tried Keron but he doesn't have any in. Also need a working idle control valve, I took mine off, cleaned it, it worked fine for a day then idle speed dropped back to 500-600 rpm. Thanks Marc Link to comment Share on other sites More sharing options...
TTRickeh Posted May 17, 2011 Share Posted May 17, 2011 I have 90910-12126-A? Link to comment Share on other sites More sharing options...
Dnk Posted May 17, 2011 Share Posted May 17, 2011 Can it not be glued back on as temp fix (loctite) Link to comment Share on other sites More sharing options...
marc_p Posted May 17, 2011 Author Share Posted May 17, 2011 I have 90910-12126-A? I was researching it and I think some people said the part was the same as Toyota gave the people who had A's, B's. It may be to do with the facelift/pre-facelift thing. I shall go and check though. How much do you want for it? Can it not be glued back on as temp fix (loctite) Well I don't use the car on a day to day basis so not too fussed about getting it fixed right this minuite but I would like it fixed asap and knowing my luck, I'd probably block it or make it even worse by trying to fix it. Link to comment Share on other sites More sharing options...
TTRickeh Posted May 17, 2011 Share Posted May 17, 2011 I was researching it and I think some people said the part was the same as Toyota gave the people who had A's, B's. It may be to do with the facelift/pre-facelift thing. I shall go and check though. How much do you want for it? 15 squid delivered? Hopefully they are the same then. Link to comment Share on other sites More sharing options...
marc_p Posted May 17, 2011 Author Share Posted May 17, 2011 15 squid delivered? Hopefully they are the same then. That's cool fella, been looking and it mainly comes up with posts on the aristo forums but they seem to think both are the same so I'll have it, send me your paypal address and I'll send it over to you as soon as I get home. Really appreciate it , god knows what I would do without this forum. Link to comment Share on other sites More sharing options...
