Dodgy Key???
den1
Hello Folks.
I have a 1998 VW Passat Tdi se 110hp :p
It has a problem that used to very rarely occur, but is NOW happening quite often!:(
Sometimes when i put the key in the ignition and try to start the car it will turn over but not start (It's as though the isn't any fuel going to the engine!)
Then I could come back 10 minutes-10 hours...and it would start 1st time! :blink:
I have had the RAC out to it and the mechanic said the codes that were coming up said..fuel auto stop ( no signal from the ECU!
This apparently could be the ECU or the KEY transponder!
Has anybody out there experienced anything like this before? :search:
ps/ I now have the car booked into VW dealer...hope it isn't the ecu
