wesmi01 Posted January 14, 2003 Share Posted January 14, 2003 Where dose the water injections get its water from. Is it the wash wipe bottle? Also it doesn’t seem to be working of late. Is it temperature sensitive or something??? Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted January 14, 2003 Share Posted January 14, 2003 The water is likely to be plumbed into the screen wash tank, underneath the battery. The pump will stop if 1: The Fuse has blown 2: The Boost pressure switch is faulty 3: You have an old style ERL pump which is prone to ingress of water and it's shorted the circuit board inside. 4: You've let it run out of water and the pump has seized. Also read the many post about ERL/Aquamist water injection Regards Pete Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 15, 2003 Author Share Posted January 15, 2003 Thanks for that!!! Is there anyway of checking it's not working for sure? I ask because the pump still needs to be mounted on some rubber washers because at the mo every time it kicks in it viberates agains the inner wing. But at the mo I hear no viberation so im woundering if it is working or not. Hmm yep an extra pipe goes to the washer bottle and it's never run out of water!!!! Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted January 16, 2003 Share Posted January 16, 2003 Disconnect the connections to the pressure switch. Doing so will trigger the pump. Regards Pete Quote Link to comment Share on other sites More sharing options...
