Twin Electric Fan Set-Up
SupraJames
Some time ago I bought a TS bonnet from Paul Whiffin, have not fitted it yet as noticed when I test fitted it the vents fouled on the stock fan shrowd. I friend of mine had a Ali fan shrowd with twin 12" fans that he had never fitted to his Supra and so I bought that off him. It has no instructions and before trying to fit it to my car I just wanted to check a few things.
1) As the fans sit on the back of the rad am I to assume the fans should "pull" and not "push" the air flow ?
2) The stock fan being run from the engine is obviously on all the time the engine is running, so I was just going to wire the electric fan to a keyed ignition power source (via fuses and relay of course), so they are on when the engine is running.
Would this be correct or do I need a temp controlled fan switch ?
The fans are not SPAL or Kenlowe but still look ok so hoping they work ok, also was told the design of the ali shrowd was suitable for autos. I have a separate oil cooler fitted and am looking at putting a small fan on that as well.
Thanks in advance :)
Thanks David :), Suck it is then. Currently have a shiny hard pipe top hose, but was reading on here they are not good, so may go back to a nice silicone one. Chap from Samco came over at Japfest was was chatting about making me up so nice hoses as well :)
  • 3 months later...
