nige Posted May 15, 2011 Share Posted May 15, 2011 Had the supra out yesterday first time in a few months apart from last week for MOT, shes running great but I noticed the revs would drop when at a standstill like it was goin to stall, I had added some Forte feul addative for the emmisions the week before could it be this? i have used it before with no problems, I'am thinking maybe a dodgey battery conection the battery was flat when I went out to start her even though shes hooked up to a conditioner all the time, any suggestions would be appreciated guys, thank. Quote Link to comment Share on other sites More sharing options...
bignum Posted May 15, 2011 Share Posted May 15, 2011 Could be a sticky idle air control valve, for some reason when the battery is flat for a while the valve parks itself in the wrong position, normally cleaning the valve helps, they get pretty gunked up, the valve is on located on the inlet plenum towards the bulkhead and has a large pipe running around the bay to your turbo inlet. Quote Link to comment Share on other sites More sharing options...
nige Posted May 15, 2011 Author Share Posted May 15, 2011 Thanks for that, I'll have a look at it. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 16, 2011 Share Posted May 16, 2011 If the battery was flat the ECU will have been reset, when reset it's normal for the car to run lumpy and not idle properly, it should sort itself out after a few miles drive. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 16, 2011 Share Posted May 16, 2011 Any time you get a dodgy idle you should check your o2 sensor voltages, as overfuelling is a cause of this behaviour. Could be the sensor is mucky and needs a clean. Quote Link to comment Share on other sites More sharing options...
nige Posted May 16, 2011 Author Share Posted May 16, 2011 Thaks for the replys guys, I think I'll take her out at weekend and really strech her legs, forgot about the ECU Nic. Quote Link to comment Share on other sites More sharing options...
