dr_jekyll Posted May 15, 2011 Share Posted May 15, 2011 hi i have crated a detaild diagramme of the twin pump setup im thnking of reason being is that i have fitted a walbro 255 but i have a nearly new stock pump doing nothing so i thaught it may be a good i dea to get them both in . my only doubt isthat this setup seems too easy to do and i think im missing something or there is something els id have to factor in please take a look and correct where needed , much love Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 16, 2011 Author Share Posted May 16, 2011 no takers ? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 5, 2011 Author Share Posted August 5, 2011 any one ? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 5, 2011 Author Share Posted August 5, 2011 (edited) OK , I JUST FOUND THIS , IS THIS ALL CORRECT? WHAT SIZE WIRE SHOULD I USE AND WILL THE STOCK FUEL LINES TO THE PUMP BE ENOUGH . AFTER THE PUMP I HAVE -6 TO THE FUEL RAIL Edited August 5, 2011 by dr_jekyll (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 5, 2011 Share Posted August 5, 2011 The stock connector terminals DO NOT like carrying double the amperage, they overheat, loose their temper and fail, they also melt the connector shells. None of this is good around a fuel tank. It's vital to either share the current load as in the diagram, or you need to use a bespoke alloy tank top drilled for your specific electrical and fluid requirements, and with either Deutsch fuel proof connectors, or Premier wire feed throughs (much cheaper option). Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 5, 2011 Author Share Posted August 5, 2011 so i should do as in the second diagramme . use the earth on the conecters as a second live to split the amps and run athocker earthto an earthing pole drilled through the tank cap. or should i ditch the stock conecter and run thicker wires through the top of the cap and have the wires on bullets outside the tank? and aditioanlly what wire on the pump ecu should i use to switch the relays for the live ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 6, 2011 Share Posted August 6, 2011 You should be OK with the second diagram. I am not sure which terminal triggers the relay, I haven't got my manuals here at the moment, sorry. My Skyline is a similar tank top setup. I turned some alloy top hats to replace the stock tank cap, so I could then use wire feed throughs and drill for proper Aeroquip hose fittings. I *SUSPECT* they may be the same size as Supra ones, but keep forgetting to check, I made 3 spares... Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 6, 2011 Author Share Posted August 6, 2011 ok , ill go for that and search around to find the correct trigger wire. thanks chris Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2011 Share Posted August 6, 2011 Look at te fuel kit Ryan has for sale, it's from Tonys old car and shows how it should be done, much like the second diagram One question though, why add another pump if it's not needed, just keep it as a spare? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 6, 2011 Author Share Posted August 6, 2011 just for headroom , last time it wasbeing mapped it started to struggle over 1 bar so im ading another pump and a fpr to get the best from my 550cc injectors. just until i can afford an ecu that can run 750s then ill go for a bosch unit Quote Link to comment Share on other sites More sharing options...
