Guest George89 Posted May 14, 2011 Share Posted May 14, 2011 Last night i had my manual boost controller set too 1 bar. After a bit of fun it spiked to 1.2 bar and then no more boost. At low revs about 2.5k you can hear the turbo spooling up which i think its the 2nd one. As the first one normally sounds much louder when it spools up. In 1st and 2nd gear their is no boost at low/medium revs, In high revs it boost too 0.1 bar. in 3rd gear it boost too 0.2 bar sometimes at 3K RPM. I am so confused i aint sure if i have blown a turbo or whats going on. I check all the intercooler piping everything looks ok. And vacuum pipes. Could i have blown a turbo? or 2? Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 14, 2011 Share Posted May 14, 2011 I would check the pipes again, it sounds like you have a boost leak somewhere Link to comment Share on other sites More sharing options...
