Supra!
JamieP
  • Replies 228
Cheers, it's got some nice parts, very handy that it already has a link stand alone ECU fitted, also uk brakes all round, brand new uk head lights, sebion bonnet is the best fitting carbon bonnet I've seen, I'm going to spray it black though and fit a RMM front lip.
Got a few parts I need sorted, got a new tail 46mm WG coming from Dan, Ryan is sorting me out some 7M injectors, putting a Bosch 044 in the tank, main things I need are updated clutch and turbo.
Nice :cool:
You should buy that NA with the Nur wide body and drop all the running gear in, you'd have two almost identical looking Supras :cool:
I cant be arsed with the work tbh Jason, the idea of the Thor car is to keep things simple and use it a lot with out worrying about chipping the paint, its very quiet also so going to try and get on track asap.
Watching this with a lot of interest :)
Is Lee (or one of his contractors) making up the manifold and exhaust piping for you?
Lee's fabricator with be doing it with Lee showing him where everything needs to be so they can get the ic piping etc all nice and neat.
I think they should make a kit myself, i can see these engines becoming very popular.
Another question Jamie (tell me to shut up if you want :D )
Are you planning on any engine mods before putting the turbo on, or just going to do it and see if holds up?
Fearless and others seem to be doing ok so im just going to see what happens mate, the engines are so plentiful and cheap its not the end of the world if it lets go, as i say, Noel has loads of them in his yard.
