Pre-oiling turbo.
black_widow87
Hi guys, hopefully tomorrow i will be refitting my new turbo after its rebuild at AET. Only part im unsure of is how to get oil through the system and into the turbo without causing any damage to the turbo. Can anyone shed some light on the procedure so i dont balls it up?!:D
Cheers in advance.
The oil will get to the turbo that fast that i doubt there'l be any dry running problems.
But the best idea is to crank the car over like chris says if you want to make sure.
If it struggles to make pressure cranking, try removing the plugs which will let it spin faster.
