tein shock recon
slip stream
any one on here had tein shocks recond as ma n/s r shock has had enough o the pot holes and crappy roads we have up here , the shocks have the soild top mounts with the adjuster for ur stiff ness on the top
any advice or some one in the know would be great thanks :D
I had a set of Superstreets reconditioned a couple of years ago, and they had to go back to Tein UK, who then had to get some of the parts from Japan.
They came back good as new, with the latest standard parts on, but it was almost as much as buying a new set, and it took about 6 weeks.
To be honest they are not worth re conditioning, better to buy a new set of dampers. They are very crude internally, not a patch on Bilsteins if you can live without on car height adjustment. Entry level for half decent on car height and damping adjustable coil overs off the shelf are probably Nitron.
What model are the shocks? If they are relatively new and still in Teins range then may be worth overhauling, if they are an old model then as Chris says not worth it.
You can download the Installation Manuals HERE, these include exploded views and part numbers for spares.
