Plug quality check please - pics
Justin
Hmmm the whiteness *could* be a sign of things getting a bit too hot in there...but as I said in my FAQ it's pretty much impossible to read plugs as they tend to only tell you the last things that happened.
What are your EGT's like?
The correct way to 'read' a plug is to look at the inner base of the porcelain (usually with an eyeglass and light) Although if you are using pump fuel its a little harder to see a burn colour. A light tan colour indicates good fueling and plug heatrange.
