Rookey Posted May 11, 2011 Share Posted May 11, 2011 Hey everyone, I'm having a bit of difficulty getting the aerotop to sit on it's rests/catches in the boot, as whenever they are carrying the weight of the aerotop, they collapse and the bits attached closest to the rear lights go flat instead of forming the needed "L" shape. Does anyone have any ideas on how I can lock these in place so it doesn't happen? I want to put a sub in the boot but I'm not going to risk it if it's not sturdy enough with the roof in! Any help is appreciated. Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted May 11, 2011 Share Posted May 11, 2011 Cant say I've ever had that Dave, they should lock in place as soon as you move then into the L shape, and need the button depressed before they fold flat. Don't suppose the release buttons are stuck? Quote Link to comment Share on other sites More sharing options...
hodge Posted May 11, 2011 Share Posted May 11, 2011 The mechanism inside is worn. You'll need to renew them mate unfortunately. I had the same issue with mine but luckily I had a spare set. Quote Link to comment Share on other sites More sharing options...
Rookey Posted May 11, 2011 Author Share Posted May 11, 2011 Ah crap, so renewing is the only option then? Does anyone have the part number as I don't have the EPC! Were they expensive to replace? Cheers Dave Quote Link to comment Share on other sites More sharing options...
Homer Posted May 11, 2011 Share Posted May 11, 2011 63670b stay assy, removable roof, rh 63670-14030-c0 jza80..aet..gz, black, trim0*, 2* 1 $86.51 63660b stay assy, removable roof, lh 63660-14030-c0 jza80..aet..gz, black, trim0*, 2* 1 $86.51 Quote Link to comment Share on other sites More sharing options...
Rookey Posted May 11, 2011 Author Share Posted May 11, 2011 Cheers Quote Link to comment Share on other sites More sharing options...
