Problem thats been worrying me for a while- oil pressure
Parry_10
Had this problem for a while- when I turn the ignition on I get all the dash/warning lights etc then when I start the engine they all go out apart from the oil pressure light which stays on for a second or 2 then goes out (sometimes it flashes twice then goes out)- it doesnt do this all the time but most of the time, seems to do it when the engine is cold and hot.
its tt-bpu should I be worrying about this?
Might be worth getting it checked by someone reputable just to be sure, but if it's going out it shouldn't be too much to worry about, I don't imagine. Have you checked your oil level recently...?
yeh oil level is on max, just wasnt sure why its doing this as im sure the pressure light should go out the same time as the others, and why it stays on for 2 secs and sometimes it flashes twice and goes out and then sometimes it just goes out with the other warning lights, very strange...
Its stock oil cooler and and oem filter, I've been told 5w-40 is best to use for bpu what would you guys reccomend me to get? What difference will a thicker oil make?
I used Silkolene PRO S 10W-50
