dude Posted May 9, 2011 Share Posted May 9, 2011 It has found the key to being proper spiteful......................Nitrous. We let it have the smallest sniff we can and the result was 918 hp at 5500rpm and 1.6 bar, it just span and ripped a set of tyres to shreds after 5500rpm so we only got 3 or 4 proper runs, its very safe on the fuel side but we have to leave it like that till we can get on a hub dyno. Now making boost from 3500 rpm. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 9, 2011 Share Posted May 9, 2011 monster (i bet it will be scary to drive that hard from 2nd or 3rd gear lol) Link to comment Share on other sites More sharing options...
mark newman Posted May 9, 2011 Share Posted May 9, 2011 thats the nuts john . Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 9, 2011 Share Posted May 9, 2011 Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 9, 2011 Share Posted May 9, 2011 holy swollen testicals batman ! Link to comment Share on other sites More sharing options...
JamieP Posted May 9, 2011 Share Posted May 9, 2011 Bit of laughing gas has made the world of difference, good luck the weekend mate, keep me updated. Link to comment Share on other sites More sharing options...
scotty71 Posted May 9, 2011 Share Posted May 9, 2011 insane nice one Link to comment Share on other sites More sharing options...
hodge Posted May 9, 2011 Share Posted May 9, 2011 Awesome John. I'm really pleased things are working out for you this year. Keep up the good work. Link to comment Share on other sites More sharing options...
Wez Posted May 9, 2011 Share Posted May 9, 2011 Link to comment Share on other sites More sharing options...
Blackie Posted May 9, 2011 Share Posted May 9, 2011 Awesome! Link to comment Share on other sites More sharing options...
Jamesy Posted May 9, 2011 Share Posted May 9, 2011 Boooom!! Awesome! Now all you need to do is find a driver who can use it properly mate Link to comment Share on other sites More sharing options...
dude Posted May 9, 2011 Author Share Posted May 9, 2011 Thanks guys, the 900ft lbs of torque will make the 1/4 mile ride 'entertaining' to say the least. Link to comment Share on other sites More sharing options...
supra joe Posted May 9, 2011 Share Posted May 9, 2011 crazy Link to comment Share on other sites More sharing options...
_Shane_ Posted May 9, 2011 Share Posted May 9, 2011 some serious power there Link to comment Share on other sites More sharing options...
Homer Posted May 9, 2011 Share Posted May 9, 2011 Excellent Good luck this weekend Link to comment Share on other sites More sharing options...
dude Posted May 9, 2011 Author Share Posted May 9, 2011 Thanks again guys, the power really comes on at 5500 thats when the cams kick in so I expect it to really pull hard down the strip, the best will come when we put the 3.4 back in then. Link to comment Share on other sites More sharing options...
hodge Posted May 9, 2011 Share Posted May 9, 2011 900 ft/lb lmao. That's totally crazy. Can't wait to see this go up the strip that's for sure. Link to comment Share on other sites More sharing options...
j_jza80 Posted May 9, 2011 Share Posted May 9, 2011 Thanks guys, the 900ft lbs of torque will make the 1/4 mile ride 'entertaining' to say the least. I can see that being hard on the drivetrain Link to comment Share on other sites More sharing options...
ripped_fear Posted May 9, 2011 Share Posted May 9, 2011 great work she looks like fun Link to comment Share on other sites More sharing options...
Scott Posted May 9, 2011 Share Posted May 9, 2011 1.6bar....... are you really aiming for 3? Link to comment Share on other sites More sharing options...
dude Posted May 9, 2011 Author Share Posted May 9, 2011 Im shocked at the difference the nitrous has made, I cant tune the fuel side as the dyno just will not hold it, we have to run in 3rd due to overspeeding the dyno in 4th and it just wheel spins, I can prob tune it at the pod from data logs as it has far too much fuel going in with the nitrous, but at least its safe, as soon as the 3.4 goes back in the spool rate with nitrous will be insane and we can run a progressive system finishing with 400hp in 4th gear. Link to comment Share on other sites More sharing options...
dude Posted May 9, 2011 Author Share Posted May 9, 2011 1.6bar....... are you really aiming for 3? The turbo guys want me to run it at 3 bar with the nitrous, the car as is SHOULD run 9's if I can keep it straight enough, I will be fitting HKS rear drag shocks at the pod but the jump needed to get in the 8's is massive so we will definatly need to run at least 2.5 bar. I'm hoping that we can run boost increasing in each gear with the increasing nitrous hit, the car should make its time up at the top end of the strip, downside is the terminal speeds are high so the consequences of a misshap are more serious, if the maths are correct high 170 trap speeds could be on the cards with the 3.4. Link to comment Share on other sites More sharing options...
hodge Posted May 9, 2011 Share Posted May 9, 2011 The turbo guys want me to run it at 3 bar with the nitrous, the car as is SHOULD run 9's if I can keep it straight enough, I will be fitting HKS rear drag shocks at the pod but the jump needed to get in the 8's is massive so we will definatly need to run at least 2.5 bar. I'm hoping that we can run boost increasing in each gear with the increasing nitrous hit, the car should make its time up at the top end of the strip, downside is the terminal speeds are high so the consequences of a misshap are more serious, if the maths are correct high 170 trap speeds could be on the cards with the 3.4. I can't stop chuckling to myself reading this. It sounds almost unreal. Brill just brill. Link to comment Share on other sites More sharing options...
dude Posted May 9, 2011 Author Share Posted May 9, 2011 I can't stop chuckling to myself reading this. It sounds almost unreal. Brill just brill. If your gonna be a bear be a Grizzly !!!!! Link to comment Share on other sites More sharing options...
Josh Posted May 9, 2011 Share Posted May 9, 2011 Keep the vids coming! Link to comment Share on other sites More sharing options...
