Recommend: Ethernet or USB Media Drive?
Jellybean
I want a Media Drive for my Network
Spec I need is
  • 1 TB min
  • DNLA certified
  • Mainly for use with the PS3 as my media station (USB 2.0 is all is required); movies and Music
  • The file system needs to be Fat32 to work with the consoles so will have to go with that.
  • Budget 70-80 pound
I would like to have an ethernet connection so I can hook up to my home network and access anywhere in the house plus the Xbox can use it.
Any suggestions, was looking at the Buffalo Ministation 1TB USB 2.0 Slimline Portable External Hard Drive but I would really like an ethernet connection
The Stora has had a software update the lets it run bit-torrent, although i haven't tried it yet, it also has configurable power on/off and has web access and LAN, it also has one USB port to expand storage if you need more.
Stora Premium after your 30 day free trial, you can simply sign up and pay by credit card via your Stora web interface for £14.95 per year
Do you recommend it?
I can't comment on the premium side of it, as i have never bothered with it, does everything i want without that, but i guess at £14.95 a year its not exactly expensive.
I keep reading about issues with a firmware update causing the HDD to get wiped ? Just reading up on the stora forums; was this fixed?
Never had a problem with my HDD getting wiped, but when i first got it, about 18 month's ago, i did have a couple of glitches with updates, and had to do a reboot, but not had any problems with recent updates.
