bit bored today, so I made this....
heckler
Of course is on an LED theme...
An PCB designed to sit around the spindle of the needles, to light them up brighter! of course, this also means the they can be used with my tacho/red line PCB set up... :cool:
http://www.internetwork.org.uk/random/needle.JPG
Just as a size comparisson, the green LED is 3mm in diameter, the 4 LED's on the PCB are 1.6mm in length!
This one lights up red...
  • Replies 63
ok, here we go - gives a rough Idea, unfortunatly the Camera always makes LED look brighter than they really are, especially when it comes to light distribution.
http://www.internetwork.org.uk/random/needle2.JPG
The picture shows more red light on the dial than there actually is.
Neat idea and very effective. When can you start producing these?
got 3 done already... Your looking at 4 per cluster for pre-facelift, and 5 for facelift....
If there sufficient interest I'll make a load up
Looks really good Si, any chance you could show what it looks like with blue dials? I quite fancy a red needles with the blue PCBs :)
Just for you Scott... ;)
http://www.internetwork.org.uk/random/needle3.JPG
They are very nice heckler, great work as always, i will take 5 (facelift) when you get round to doing more.. by the looks of it .. they will be popular :)
will you need ours in return or do you make the housing aswell ?
nope, there just PCB's as in the first picture...
