wheel stud
Lude
Guest powerslide
r u after stock ones or after market ones? if it's after market, u need to make sure u get the correct size as they might not fit your spanner
Guest powerslide
p.s....if it's stock ones, iv got some lying around, let me know if you need em, pay the postage and you can have them
Dude just order 1 new from from toyota they are like £3 and collect it, problem is using used they are 15 years old and have a tendancy to snap.
Also all the studs are the same, so front back makes no differance.
I have new ones if you preffered to new and also if i was you id change that side and not just 1, as when i had 1 snap i took the rest out and they all had hairline cracks at the spline.
im after a new one yes,
mine are all in good condition, so not cracked or anything, i just need one as i had a bad wheel nut & messed the threads up slightly.
if you have a new one PM me :)
