stevie_b Posted May 7, 2011 Share Posted May 7, 2011 I've had a squealing sound coming from the engine bay for a while, which I'm fairly sure is from one of the auxiliary belt pulleys. I've changed the belt itself for a new OEM one, changed the crank pulley for a new OEM one, and changed the belt tensioner for a second hand metal-wheeled OEM one. The squealing still persists. I'm guessing it's probably the power steering pump pulley bearings, but are there any tests I could do to confirm that? I've tried listening to the pump with a breaker bar acting as a stethoscope / sounding bar: sure, it sounds rumbly, but without having anything to compare it with it's hard to know if it's excessive or not. Many thanks for any help you can give. Quote Link to comment Share on other sites More sharing options...
imi Posted May 7, 2011 Share Posted May 7, 2011 I used to spray some WD40 on the power steering pulley and it used to solve the squeal. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 8, 2011 Author Share Posted May 8, 2011 Thanks imi, I'll give that a go. Quote Link to comment Share on other sites More sharing options...
