Just got my Supra from Thailand and my other 2JZGTE SWAP
supra3000GT
  • Replies 935
WOW !!
Some seriously inflated prices going on there - is that due to import tax in Thailand ??
J.
If the guy has registered one of his business as a regular importer and this ultimately benefits the country he can claim import back however.....
due to import tax regs there your "luxury" vehicles are hit with high tax which makes anything from your 5 series bmw right through to your enzo's 3 times the price of europe.
No, he can't claim import duty back even if he was an importer.
Import duty only applies to imports, BMWs are made in Thailand as are many other makes.
New gearbox sheptans stage5
1500 ft lbs
Dodson Motorsports Extreme Gearset
Dodson Pro Max clutch/Alloy version 12/12
ShepTrans Billet 1-R shift fork
Dodson Gear Selector Shaft 2-4-6
Dodson Gear Selector Shaft 3-5
Dodson HD synchro set
Dodson FWD clutch ( Sheptrans spec.)
Dodson FWD Output shaft
Dodson Billet Rear Reduction Gears
Dodson Heavy Duty clutch return spring retaining clips
Dodson Piston shaft seals
Dodson FWD retainer
Dodson Mechanical lock #1
Dodson Mechanical lock #2
Dodson Selector Piston Shims x 4
Dodson O-ring and seal upgrade kit
Dodson Oil pump shaft upgrade with blueprint
Dodson Reusable transmission filter
6 neodymium magnets
Dodson High temp rear differential oil seal
ShepTrans FWD ball retainer
ShepTrans FWD clutch Fluid
OEM Fwd output seal
ShepTrans Billet Thrust plate
Dodson 2,4,6 Thrust bearing circlip
Dodson 1,3,5 Thrust bearing circlip
Oem Nissan transmission pan gasket
Transmission and Rear differential Fill plug gasket (2)
Rear differential drain plug washer x1
Oem Nissan Rear differential side seals
T1 rear diff brace
Arp Rear diff bolt upgrade
Dodson Surge/Baffle kit
Dodson Drag Sump/ Billet Pan
Edited by supra3000GT (see edit history)
  • 3 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 4 weeks later...
Finally,making big decision to get this Nissan skyline KPGC10 year 1973. I should get this car 5 years ago because I will pay half price what I paid now 250,000 USD.
The car condition only need some car detaling and cleaning fuel system.
  • 1 month later...
  • 2 weeks later...
