rxv8 Posted May 5, 2011 Share Posted May 5, 2011 having a clear out...these are £262.00 on ebay...first £125.00 gets it... This device is possible to act as a monitor for various sensor functions in the vehicle by connecting it with the F-CON SZ. MONITORING FUNCTION Engine RPM: Displays the engine RMP power supply voltage. Display Battery voltage. Air Flow output value: Display the below information according to the following, Hot wiring Type = Voltage Carlman = Frequency Intake Air Pressure = Voltage of pressure sensor Ratio of air to fuel: Display the ratio or percentage of air & fuel. Injector opening ratio: Display the opening ratio of injector. Circulating Water Temperature: Displays the water temperature of the circulating coolant water. Fuel Revision Value: Displays the Fuel Revision/Compensation Value which is adjusted by the F-Con SZ. Ignition Revision Value: Displays Ignition Revision/Compensation which is adjusted by the F-Con SZ. Intake Air Pressure: Displays boost pressures. Speed: Displays driving speed (* This function is not applicable to some vehicle models). Link to comment Share on other sites More sharing options...
rxv8 Posted May 6, 2011 Author Share Posted May 6, 2011 sensible offers... Link to comment Share on other sites More sharing options...
rxv8 Posted May 6, 2011 Author Share Posted May 6, 2011 any interest before ebay... Link to comment Share on other sites More sharing options...
rxv8 Posted May 16, 2011 Author Share Posted May 16, 2011 ok this was not collected at the weekend,so still for sale...reduced to £100.00 Link to comment Share on other sites More sharing options...
Swampy442 Posted May 16, 2011 Share Posted May 16, 2011 Do you know if this will work with the Pro V? Link to comment Share on other sites More sharing options...
rxv8 Posted May 16, 2011 Author Share Posted May 16, 2011 hi been told it works on the pro v aswell... Link to comment Share on other sites More sharing options...
rxv8 Posted May 20, 2011 Author Share Posted May 20, 2011 bump... Link to comment Share on other sites More sharing options...
wilkorangerover Posted May 22, 2011 Share Posted May 22, 2011 pics? Link to comment Share on other sites More sharing options...
rxv8 Posted June 2, 2011 Author Share Posted June 2, 2011 still got it...£100.00 offers... Link to comment Share on other sites More sharing options...
SupraAyf Posted June 3, 2011 Share Posted June 3, 2011 Do you know if this will work with the Pro V? I do know that it won't work with version 3.3 of the V Pro. Thsi might help: http://www.nengun.com/hks/f-con-navigator Link to comment Share on other sites More sharing options...
