t-one234 Posted May 5, 2011 Share Posted May 5, 2011 i made full use of the search button, but couldnt find much im looking at treating my supe to a proper service as its not running its best what i need to know is, where can i buy the bits i need? i doubt my local auto factors will have the parts im wanting to change the oil and oil filter fuel filter plugs/leads and ive also got a HKS mushroom filter on it which is supposed to be green but is actually black, not sure where i can find a replacement which oil do people recommend using? its an NA also im looking to replace the cam cover gaskets so i need to know where to buy those from is there anybody on here that can supply the parts? is there anything else i should service? sorry, ive only had the thing a month lol [OOPS][/OOPS] Quote Link to comment Share on other sites More sharing options...
JamieS Posted May 5, 2011 Share Posted May 5, 2011 Opie Oils would be a good place to start. They're a trader on here. Quote Link to comment Share on other sites More sharing options...
stu861 Posted May 5, 2011 Share Posted May 5, 2011 look at this mate very heplfull information on here http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine.&highlight=oil Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 5, 2011 Share Posted May 5, 2011 (edited) Bin the green HKS filter mesh as their crap, Chris Wilson does a replacement that will fit but be much better at filtering (trader on here) Get the leads, cap, rotor arm, oil filter, fuel filter, cam cover seals etc from Toyota, try Steve Manley at Inchcape 01865 291333 Try your local motorfactors for the oil (5W 30 semi syn o/e or 10w 40 fully syn) or see how much Opie Oils can do it for (trader on here) http://www.sparkplugs.co.uk for the plugs, fit iridium as they last longer so less plug changes which on an na is a definite bonus. Check the FAQ section Edited May 5, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
cje001 Posted May 5, 2011 Share Posted May 5, 2011 Im getting the replacement green filter off Chris Wilson mate, i`ll post a snap of it on here for you when it arrives Quote Link to comment Share on other sites More sharing options...
t-one234 Posted May 5, 2011 Author Share Posted May 5, 2011 yeah, if you could post up a pic that would be great much appriciated cant wait to finally start sorting her out and making her run like she should Quote Link to comment Share on other sites More sharing options...
Nic Posted May 5, 2011 Share Posted May 5, 2011 Toyota Service Repair Manuals Maintenance Quote Link to comment Share on other sites More sharing options...
Nic Posted May 5, 2011 Share Posted May 5, 2011 I'd swap the HKS induction kit for a stock airbox, contact Keron Toyota Part Numbers 23300-49195 Toyota Fuel Filter 19101-70020 Toyota Distributor Cap 19102-46011 Toyota Rotor Arm 90919-21521 Toyota Spark Plug Lead Set 89465-19615 Toyota Oxygen Sensor - 2JZ-GE x 2 FAQ: Spark plugs FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine. Quote Link to comment Share on other sites More sharing options...
