will these fit ?
TRD DAN
The offsets are too small, the wheels/tyre would stick out past the arches.
If you compare those wheel sizes/offsets to the stock wheels, the fronts would extend out 46mm towards the wheel arches, the rear 30mm.
its not a problem rolling the arches even with a slight flare, was more of a concern with clearing they brakes ?
cheers dan
The spokes on the work emotion cr kai should clear the larger brakes, but I'd test fit them if you can to be sure.
You will need to either flare the arches quite a bit or add wheel arches, these are 18x9 +32 on the front and needed the arches rolling, the wheels you are asking about would sit another 1.5cm further out.
vbpgimage.php?do=full&p=741&d=1134500967
