TRD DAN Posted May 5, 2011 Share Posted May 5, 2011 looking at some work emotion cr kai's in fronts 17x9 et17 and rears 18x9.5 et20 anyone know if they will clear uk specs ?? as im not in a position to try them for size so to speak cheers dan Quote Link to comment Share on other sites More sharing options...
fastnfurious Posted May 5, 2011 Share Posted May 5, 2011 what's the front offset like? ET20 on a 9.5" for the rear will definitely scrub the inner fender, ET35 will just be perfect otherwise a higher figure. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 5, 2011 Share Posted May 5, 2011 The offsets are too small, the wheels/tyre would stick out past the arches. If you compare those wheel sizes/offsets to the stock wheels, the fronts would extend out 46mm towards the wheel arches, the rear 30mm. Quote Link to comment Share on other sites More sharing options...
TRD DAN Posted May 5, 2011 Author Share Posted May 5, 2011 its not a problem rolling the arches even with a slight flare, was more of a concern with clearing they brakes ? cheers dan Quote Link to comment Share on other sites More sharing options...
Nic Posted May 5, 2011 Share Posted May 5, 2011 its not a problem rolling the arches even with a slight flare, was more of a concern with clearing they brakes ? cheers dan The spokes on the work emotion cr kai should clear the larger brakes, but I'd test fit them if you can to be sure. You will need to either flare the arches quite a bit or add wheel arches, these are 18x9 +32 on the front and needed the arches rolling, the wheels you are asking about would sit another 1.5cm further out. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 5, 2011 Share Posted May 5, 2011 It can be done if you are willing to work at it, ive had 11" et24 on the front of mine with stock arches, with a heavy roll/pull they cleared, the paint did crack on both arches though. Quote Link to comment Share on other sites More sharing options...
