Vagnum Posted May 4, 2011 Share Posted May 4, 2011 Hi everyone i need a front panel, the one that bolts between both wings and the headlights sit on ?? Link to comment Share on other sites More sharing options...
straightsix Posted May 4, 2011 Share Posted May 4, 2011 Get in touch with Keron - he sells brand new ones. TBH I wouldn't use a secondhand one as they're usually bent! Make sure you know which one as there is a weld on panel (slam panel) and then the flimsy affair that bolts to that. Link to comment Share on other sites More sharing options...
little num Posted May 4, 2011 Share Posted May 4, 2011 I have both in mint conditon, reason i have them is i have a rear ended supra so front end is perfect. Drop me a pm to the 1 you need and i will take pics if you like, they are silver but will obviously need spraying if its the welded bit you need. Link to comment Share on other sites More sharing options...
absz Posted May 4, 2011 Share Posted May 4, 2011 I have both in mint conditon, reason i have them is i have a rear ended supra so front end is perfect. Drop me a pm to the 1 you need and i will take pics if you like, they are silver but will obviously need spraying if its the welded bit you need. If vagnum does't take them can you pm me a price for both panels as i need them for a project.! Link to comment Share on other sites More sharing options...
keron Posted May 5, 2011 Share Posted May 5, 2011 ive got new in stock if needed..... Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 5, 2011 Share Posted May 5, 2011 i have a brand new one still in packet too Link to comment Share on other sites More sharing options...
