how tight to tighten up wheel nuts?
Lude
i had some aftermarket alloy wheel nuts,
put them on with a socket set, hand tight, didnt stand on them as you see people doing.
they were fine for months & months,
then when ive changed the wheel, put them back on ive messed the threads up on them?
tbh they are awful & ive purchased new steel ones, but do they really need to be on stupidly tight?
or just until they are tight without too much force required ?
I took off all my wheels at the weekend and without a torque wrench just nipped then up equally and then gave then a slightly tighter turn with the standard Supra wrench. If you are jumping on them, you are going to damage the threads. I have never had a nut come undone in 18 years of motoring.
H.
90% of wheel nuts / bolts I remove are OVER torqued. There's something in the human psyche that tells them wheel nuts must be super tight, yet they are happy to tighten other life supporting fasteners to half their correct torque :) The Supra manual torque figures are for stock nuts, if using none stock nuts on none stock rims, the correct torque figure may be less, maybe more
yea i didnt do the nuts up super tight,
yet the threads are F't on 1 or 2 of them?
guna put it down to poor quality nuts, hope my new ones are a bit more robust. will only just nip them up :)
Use a torque wrench, 75 ft lbs ;)
I've always gode with 120-130nm. That feels suprisingly easy to both apply and get off. My experience and from what I've heard is that its more important that alle nuts are tightned with the same torque than how much torque (within reason of cause).
Get that torque wrench!
I'm 120-130nm to!
