No idle and rarely purging fuel on new single???
Bailey.
Today was the first attempt to start my single build, problem is the fuel pump only kicks into to purge when you turn the ignition on about 1 out of 10 times you try it, The setup i have is
Hks f con
Standard(blitz access) ecu
800cc low impedence injectors
Heckler resistor pack
sard fpr
All the car did originally was start and once running cut out, and now it does this every now and again in between not starting at all.
Tomorrow i will check voltage to the pump, pump ecu connections and relays etc.
Anyone else have any ideas? Im not really worried, as im sure its something silly, but any other ideas would be helpful, and may shed some light on this issue.
Heres a small vid of it starting
