Fitting New wing
ManwithSupra
I am fitting a new wing hopefully next week as the one i have is damaged.
Has anyone done this and is there a "How To" on it ?
I know its a bolt on wing but just wanted to make sure that there isnt going to be any suprises along the way.
If not then i will post the how to when i muddle through it,
I removed the rear wing from my car yesterday. Asuming your car is the same as my 93j/spec, you need to remove the plastic panel under the boot lid. This is held on by push in clips, you need to pull the panel gently from one corner until you hear the clip 'pop'. Once you get a couple off, the rest are easier. There are four bolts holding the wing on, i'm sure they were 13mm. Undo these, give the wing a nudge and you should be in busines.
HUH??? :help: What are you on about dude?
The guy wants to now how to remove the FRONT wing, why would he need to remove the panel under the boot lid?
After reading it again, he probably is on about one of the front wings.
The quickest way to remove these is sideswipe the barrier at around 70. Although this is a highly counter productive method.
