Split charging.
creative
The time has come to start thinking what I need for the install in the ute.
As I am going to be running a pair of 15's I think I should go a split charge system. I kniw how these work but I refuse to pay $200 bucks for one when I can do It myself.
The problem I have is a lack of internet to research it, so are there any knowledable folks that could give me a parts list so I can just go and buy the bits?
Will be running a class d mono amp off the extra battery with a capacity of 1114w rms.
Thanks gents!
  • 4 weeks later...
You might probably need a hefty solid state relay, I used to run a split charge system in my little van and it could happily pop a 15amp fuse.. Not straight away but it gets hot. I ran a wire from the alternator charge light to the relay coil so that when it was running it would join up the two batteries.
Probably find something on a camping site or something of that nature :)
